new at diagnostics
Car: 92 Z-28
Transmission: THM700R4
new at diagnostics
My 305 HO is missing and lacks power. One of the first things I checked was the fuel pressure to see if that was the problem as I had a similiar problem on my RS. Here's what I did and the results: First I hooked up the gauge to the shraeder valve and hung the gauge so I could see it inside the car. When I turned the key on, pressure shot up to about 50 psi, but went down within the first minute or two to 0. I did the same thing 3 times w/ all the same results. Then, I cranked it up, pressure stayed steady @ about 40 psi. Shut the car off and pressure went to 0 in a short period of time. My Haynes and Chilton manuals say that the pressure should stay steady. With the pressure at 50 psi I didn't think there was a problem with the pump. Maybe I am wrong. NOt holding the pressure may be a problem that wasnt covered in the manual.
I have replaced the fuel filter, and checked the timing, everything is fine for those items. I have yet to replace the plugs but I don't think that is the problem. What do ya'll think? Help!!!
in advance
in advance Member
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
Re: new at diagnostics
two things that could cause the pressure to drop quickly are your fuel pressure regulator or a leaky injector. good luck
or a bad anti drainback valve in the pump. Or a leaky fuel line. If the fuel pressure is right when its running, you should do a volume test. Some fuel pressure gauges have a tube coming off with a little valve. With the engine running, point tube into bucket and push button. See what happens. Lots of times you can find a pump that can maintain pressure in the acceptable range and not deliver the proper volume.
Car: 92 Z-28
thanx for the help. do you know if this would specifically cause the motor to run terribly? I could not find any fuel leaks and I do not smell gas at all.
LJNOWELL, could you explain what a volume test is and how it is carried out? I do not have such a gauge that has a bleeder hose on it, however, I thought that the bleeder valve on that type of gauge was only to relieve the pressure on the hose for my pressure gauge. I did not know it was useful for some other purpose.
Would a bad antidrainback valve cause the engine to miss and lack power?
I am going to look into how to check the FPR for proper functioning. Any other help is GREATLY APPRECIATED!
87ColdAirIroc-Z
Nov 9, 2001 04:31 PM
