Code 25 and need help
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
I understand that with a code 25 i need to check my MAT sensor and wiring. I have a '91 RS 3.1l V6, MPFI. Where exactly is the MAT sensor?
Thanks fellas
Thanks fellas
Engine: 5.0l TBI
Re: Code 25 and need help
Gotcha, I just noticed that i actually had to move it. I installed the TPI air box on my car and i had to relocate that sensor. I drilled and tapped a hole into the MAF housing and put it there. I traced my wires and noticed i had a bare spot that was shorting out. Looks like that did the trick. Thanks anyways
