Read this help me quick
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
would the head be a bad choice it is a 2.02 /1.60 head used on a 74 camaro .I want to put them on a 305 ,i have a 470 lift cam right now how much would it help.the casting # is 333881 will the valves fit the 305
Car: 86 Camaro
Re: Read this help me quick
The heads should fit and flow fine. Problem with puting the 350 heads on your 305 is your combustion chamber will now be larger, thus dropping your compression (bad thing).
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
2.02/1.60 valves will hit the cylender walls on a 305, u need a 4" or larger bore for that size valves to work
If you have a stock LG4 short block, your compression ratio will be approximately 7.3:1 with those heads. If the engine has been rebuilt, it'll possibly be even lower still.
Probably not a good idea.
Flow will be bad; even though the valves probably won't actually hit the block (they might, but probably won't), they'll be so close to the cyl walls, that they may well flow LESS THAN the stock 1.84" 305 valves, because at least the material can get around the edge of the smaller valve. Doesn't matter if the cam lift is .700", if the gases have to flow through a .050" crack to get from the port to the cyl.
Probably not a good idea for that reason, as well.
There is no possible scenario in which it's a good idea.
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Do a search, nobody on this board has ever hit the cylinder wall with a 2.02 valve.
If they have it has not been posted.
Lots of other reasons not to 350 head a 305.
no prob thanks for the info i got a sweet deal on 338882 and 3973370 heads for 75.00 deal both complete
No improvement there. Still a bad idea.
Smogger heads are best melted down and forgotten.
Hotrodboba400
Dec 10, 2019 07:07 PM
