PLEASE HELP!!!!CAN A LS1 STARTER BE USED IN MY 1991 350CI CAMARO?
Hi, what I am asking is can a ls1 starter be used in a older camaro, I ask this because I read some were that you can but when I put both starters side buy side the bolt patterns are different and the teeth on the gear also look different.
Help with this question would be great!!!!
Thanks!!!!
Thanks!!!!
Re: PLEASE HELP!!!!CAN A LS1 STARTER BE USED IN MY 1991 350CI CAMARO?
Thanks for answer, I did not thing it would fit but my be if it was modified it would but I guess not worth the time. but know I got bigger problem the motor is actually seized, it looks like it threw a rod. Thats what happens when you take a change buying a car that does not start.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i do believe the LT1 starter will
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
