Idleing problem
Old Apr 7, 2008 | 12:34 AM
Nater2491's Avatar
Idleing problem
So my car has been running fine. until last night when i go to start it and it doesnt start. i give it a little gas and it starts but if i let off the gas it dies instantly. So i get it home and leave for a bon fire and when i come back three hours later its fine, it starts and holds the idle. But i dont want to drive it until i know what the problem was and make sure it is solved. anyone have any ideas ?car is 86 tpi 305 camaro
Old Apr 7, 2008 | 08:19 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: Idleing problem
First of all, did it throw any troublecodes ? IF so , check them out.
It isnt much to go on but check the standard stuff like sparkplugs, wires, rotor/distributor cap. Is it getting the right amount of fuel ?..
more info would be nice, orelse check those things
Old Apr 7, 2008 | 09:09 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: Idleing problem
A vacuum gauge and fuel pressure gauge could be your best friends.
Old Apr 7, 2008 | 09:15 AM
Theking's Avatar
Car: 1989 IROC-Z
Re: Idleing problem
Yeah I forgot about that (I have Autometer Cobalt, fuelpressure, vacuum and Air/fuel ratio inside on my pillar..)
So check that at first, starter gas can also be used to find vacuumleaks.. a gauge is always the best but starter gas will work..
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
