Problems starting...clueless
Old Apr 7, 2008 | 11:40 PM
PatriotPride81's Avatar
So as of last night (sunday 4/6) my '92 305 TBI Camaro RS was running fine. When I tried to start it up this morning, it was a no go. On the first couple tries, it would crank and crank but wouldn't turn over. After a couple more tries it finally just seized up and wouldnt even crank when the key was turned. Starter was replaced not too long ago, the battery's holding a normal charge, the engine just wont turn over or crank.
I honestly am at a loss of words here...what could be the problem. Havent checked the spark plugs for a few months but they should be clean. And just had the catalytic converter replaced along with a bunch of other stuff (fuel filter, tensioner, ac pully, loose tranny bracket).
What do you guys think it is?
Old Apr 8, 2008 | 12:05 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
Re: Problems starting...clueless
go back to the old stand by's, fuel and spark. it's tbi so you can SEE if it's getting fuel. once you rule that out pull a plug and see if it'll shoot a spark to the block.
also, turn the key but don't start the car, hear a fuel pump?
Old Apr 9, 2008 | 01:15 AM
wound up being the fuse for the coil went out. Quick fix and only about 30 bucks at kragen. There was no spark going to so I figured it was either the coil or something around there, the plugs were fine.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
