Distributor base not flush with engine base
Old Apr 13, 2008 | 01:50 AM
whatdayasay's Avatar
I'm reinstalling my distributor on my 90' V6 3.1L engine. The distributor base is about 1/16" or 1/8" away from the mating face. I put the distributor in and turned the engine over with a socket hoping the dizzy would fall in place.
I'm not sure i understand the screwdriver technique. My oil pump shaft doesn't have a groove in it at the top of the shaft for turning. Do I take the screwdriver and run along side of the shaft as far as it will go and try and move the hex portion of the shaft. I can't tell where the hex portion starts but I assume it is below the visual portion and below where the shaft goes into the pump.
Old Apr 13, 2008 | 07:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Distributor base not flush with engine base
The 3.1's are different then the SBC distributor setups. As you found there is a hex drive instead of the screwdriver style oil pump drive. And there is an O-ring to seal from oil in place of a gasket.
If you haven't replaced the O-ring do that before dropping the distributor in. Oil leaks from that area are common on these engines.
Because of the O-ring they just don't drop down. Need to push the distributor down into place. Put some oil on the O-ring first.
RBob.
Old Apr 13, 2008 | 08:56 AM
i just want to confirm your reply.
i need to push the distributor down in place? push it down hard or let the hold down bolt do it? is a gap between the 2 faces ok ?
Old Apr 13, 2008 | 11:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Ah, I fixed my post. Instead of "just just drop down", it is "just don't drop down."
Do not use the bolt to pull it down. You should be able to push it into place. With the hex drive you should be able to rotate & wiggle the distributor to get it into place.
If you have an auto the TV cable is also there. It may get (or a wire) between the distributor and block.
RBob.
Old Apr 13, 2008 | 08:01 PM
i had to persuade the dizzy with a few taps with the rubber mallet. the car started and ran fine. i forgot to look at the oil pressure. i check the timing next.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
