my 383HSR!!
Old Apr 13, 2008 | 07:04 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
my 383HSR!!
well i got the motor in and the cam broke in. she runs real good it feels very promising!!
Old Apr 13, 2008 | 07:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: my 383HSR!!
oh no! is that stock manifolds for exhaust? or did you use those to break in the cam?
other than that i'm glad you got it up and running. Cant wait to see how it runs on the dyno and/or track. I'm excited for my build to finally start coming around. hoping for startup in about 3-4 weeks
Old Apr 13, 2008 | 09:42 PM
tekkitan's Avatar
Car: 87 IROC-Z
Re: my 383HSR!!
nice! i am trying to decide if i want to do HSR for my 383 or carb it. i figure carb would be easier for tuning, but then HSR would be very nice as well.
anything to help me decide?
Old Apr 13, 2008 | 10:14 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Re: my 383HSR!!
Lookin good, but why did you use stock Throttle body, and stock exhaust mani's? Also, how do you like those patriot heads? I was going to get a pair if my stock 083's were cracked, but they wernt cracked, and my wife wouldnt let me buy new ones.
Old Apr 13, 2008 | 11:15 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Re: my 383HSR!!
the manifolds are just for break in. heard some stuff about the temps during cam break in messing with ceramic coatings. didnt want to chance it. the stock throttle body supposed to be good for like 400 hp right.
Old Apr 13, 2008 | 11:28 PM
tekkitan's Avatar
Car: 87 IROC-Z
Re: my 383HSR!!
maybe, but the 383 *should* be able to achieve more than 400hp
all depends on how it's built
Old Apr 13, 2008 | 11:38 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: my 383HSR!!
Also having a 383 HSR I can tell you that I went from a BBK 58mm throttle body to the Accel 1000 CFM throttle body. My tuner and I got bored threw it on there just to see what would happen. It resulted in 10 rwhp and 10 more ft lbs of torque to the wheels. My throttle response also went up. I would recommend getting an aftermarket TB and go at least 58mm.
Old Apr 14, 2008 | 09:26 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: my 383HSR!!
yeah a 58mm would work well on that motor. I just ordered a 58mm holley to go with the stealth ram
Old Apr 14, 2008 | 11:14 AM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Re: my 383HSR!!
the throttle body is among the numerous things on my wish list
Old Apr 14, 2008 | 12:20 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: my 383HSR!!
Interesting post about the throttle body with good back to back dyno comparisons. That should be a thread of its own.
Old Apr 14, 2008 | 12:42 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: my 383HSR!!
I did in the Aftermarket Product review....Didnt get much attention though? On that note, I know summit makes TB's, how well do they flow compared to Holley's and BBK and Accells?
Old Apr 14, 2008 | 01:06 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Re: my 383HSR!!
ihave kinda been looking at that az speed single blade. but its kida pricey
Old Apr 14, 2008 | 01:19 PM
Car: 1989 GTA
Engine: 369 TPI
Re: my 383HSR!!
I bought one and the problem is that it is set up for the LT1. Had to do some wire conversions to make it work and use the LT1 TPS and IAC. Had to work on the portion where the throttle cable attaches. Also had to buy the post where my cruise control fits.
Old Apr 14, 2008 | 02:52 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: my 383HSR!!
Im doing my 383 carbed as of right now. My setup is going to be steller. HA anyways i did have the hsr for it, but went carbed for the fact that I have no time to tune.
Old Apr 14, 2008 | 11:44 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Re: my 383HSR!!
check her out running
Old Apr 14, 2008 | 11:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: my 383HSR!!
NICE!! sounds really good man!
86White_T/A305
Theoretical and Street Racing
Jul 26, 2011 01:54 AM
peepsrs
Jan 26, 2011 12:24 PM
WASyL
Alternative Port EFI Intakes
Jul 13, 2010 05:37 PM
