Car has no fire...help
Old May 13, 2008 | 11:28 PM
88CamaroGirl's Avatar
Car: 88 Chevy Camaro
Engine: 2.8 L V6
Transmission: stock
Axle/Gears: stock
Car has no spark...help!!!
Ok I have an 88 camaro 2.8 v6 and having big problems...the cars been sittin a while and thought it was just the fuel pump..nope. I'm not getting any spark at the plugs..I've replaced the fuel pump, relay, fuel filter, plugs and wires, distributor cap, rotor, coil, ignition module, and ECM...still nothing! I'm about to go crazy trying to figure out what the problem is any ideas would be great!
Kat
Old May 13, 2008 | 11:37 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: Car has no fire...help
Just to be clear, you're not getting spark at the plugs, or no fuel out the injectors, or neither?
About the only thing left in the ign system is the pick-up coil, and they do occasionally go bad.
Old May 13, 2008 | 11:49 PM
Engine: 2.8 L V6
Transmission: stock
Axle/Gears: stock
sry, yeah im not getting any spark at the plugs, i was just told today about the pick-up coil....
Old May 14, 2008 | 03:25 PM
Engine: 2.8 L V6
Transmission: stock
Axle/Gears: stock
Ok, I'm going out tomorrow to get the pick-up coil, I really hope that's the problem cause I'm really at a loss with this...any more ideas would be great and thanks angain.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
