cold start injector and egr temp probe
Old May 22, 2008 | 10:53 PM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
i have an 88 GTA w/ a 305 tpi. i removed the cold start injector and egr temperature probe thing in prep for my swap to speed density (since i had my intake apart).. in doing this, will this screw with the computer and throw a code or something if i need to drive it while its still setup for MAF? what does that temp probe actually do? and as for the cold start injector, does cold in this case stand for engine is equal to ambient air temp or acutally cold?
Old May 23, 2008 | 11:20 AM
72vega's Avatar
Re: cold start injector and egr temp probe
nobody?
Old May 24, 2008 | 10:09 AM
Vader's Avatar
The cold start conrol is referenced to coolant temperature alone, not air temperature. The unit also contains a ersistance heater, so once the ignition is on and a cold start injector has been operated, it won't operate again until the thermal element in the control has cooled down. This prevents multiple shots from the cold start valve and reduces the possibility of flooding.
The EGR diagnostic temperature switch is supposed to operate when the EGR opens. A disconnected or failed switch will set a "32" during cruise if the EGR valve is opened, but shouldn't cause any real operational problems.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
