help with backfire
Old Jul 1, 2008 | 12:50 PM
1992CamaroRS305's Avatar
help with backfire
the only time i hear my camaro backfire is when i have it in park and rev it up... after i rev it up and right when it starts to idle down it backfires... like right after i let off the gas... what would cause that? btw, im not a good mechanic... i use the haynes repair manual for help lol
Old Jul 1, 2008 | 08:21 PM
Re: help with backfire
Old Jul 2, 2008 | 05:16 PM
parkerchance's Avatar
if my car hasn't warmed up for a couple of minutes it does the same thing.
Old Aug 12, 2008 | 08:04 PM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Axle/Gears: Borg warner 3.08's
My car does the same thing. Does anybody know why?
Old Aug 14, 2008 | 12:47 AM
superscotty19's Avatar
Sorry, I don't have a solution but I wanted to chime in: mine's doing the same thing. I created a post that has more details but it's driving me insane cos I'm also running rich (smells bad) and getting poor mileage
Old Aug 14, 2008 | 09:52 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
backfiring through the carb (or if FI intake) or exhaust? through carb/intake is a lean condition and through the exhust is a rich condition. after we know that and you induction (carb, TPI TBI), people will be able to help you better.
Old Aug 14, 2008 | 10:24 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
back fires are cool... esp if theres mad fire yo.. but uh more details would help
Old Aug 14, 2008 | 10:45 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Mine does it too. Only in park while revving it (350 TPI). It's more of a pop from the exhaust than a loud backfire. I can say that I have had almost new cars before that have done the same thing. My GTA does run rich though, I know I probably need to change my plugs.
Old Aug 14, 2008 | 03:05 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
retarted timing
valve float-springs
hei-not very powerfull at high rpms without some help
Old Aug 15, 2008 | 07:20 AM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
My car is a 85 TA with non computer controled carb and vacuum advanced HEI distributor. My car is also running a bit rich. You can smell it in the exhaust. I set my timing back to the number 4 on the tab but it still does the same thing. Also all the polution cantrol junk and cat are gone. Thanks for the help.
Old Aug 15, 2008 | 08:45 AM
impaled's Avatar
my 85 IROC w/carbed 350 was popping through the carb when i messed up and ran 87 through it. i decided not to retard the timing and chose to just run premium.
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
