Car is not restarting
Old Jul 14, 2008 | 11:11 AM
Greygoat's Avatar
Hello, Im sure you guys have heard this problem before so hear it goes. My 89formula 350 would start and run and then it would not restart after a while. Its not the start cuz it turns over. So i thought it could be something with the ignition or something. So i replaced the cap and plugs and wires were ok. I put it back on and everything ran fine until i stopped it. The car started to feel sluggish and felt like it was missing and was loosing power. I stopped it and it would not restart until later. Im thinking of takin it to the mechanic but before i do please advise to see if i could do anything before i take it.
Old Jul 14, 2008 | 11:27 AM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
Re: Car is not restarting
Got the same problem with mine. Mechanic said bad fuel injectors. Have them checked out.
Old Jul 14, 2008 | 01:51 PM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
Engine: 350 zz4, 305 tbi :(
check the plug wires and make sure they are all on and also check the chip on your key and make sure it isnt messed up the security system on those cars can do that
Old Jul 14, 2008 | 10:01 PM
Greygoat's Avatar
I had checked the plugs the car ran fine but then i turned it off for a while and the car was running like crap and the key is fine.
specialized
Jun 18, 2022 09:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 26, 2015 04:59 PM
Linson
Aug 21, 2015 02:12 PM
zeitghaist
Aug 18, 2015 07:33 AM
