dip stick change question
Old Jul 31, 2008 | 03:48 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
my dipstick tube on my 85 iroc is bent to hell, its extremly hard to get the dip stick out. theres a 91 firebird with a tbi v8 at a local yard. could i use the tube and stick from it?
Old Jul 31, 2008 | 04:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: dip stick change question
They should be the same.
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I think they are located on opposite sides but i could be wrong
Old Jul 31, 2008 | 04:14 PM
theyr both on the passenger side. the 91 apears to be a bit longer? well, atleast the stick its self is.
Old Jul 31, 2008 | 04:45 PM
1fastrock's Avatar
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
if they arent the same length id be very carefull. my dipstic hit and broke off on my last motor and i ended up having to rebuild the whole thing!!! it sucked!!!
Old Jul 31, 2008 | 04:55 PM
the dip stick hit what? what were you doing?
Old Jul 31, 2008 | 05:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The dipstick isn't a precision measuring device. If it's close, it'll be fine.
Old Jul 31, 2008 | 05:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you get the tube from a different car, get the dipstick, too. They have changed lengths over the years.
Several years ago while poking around a pick & pull, I noticed none of the cars had dipsticks. Story was gangbangers liked to make knives out of them.
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
the_nikfive
Aug 11, 2015 02:46 AM
Leggman1
Aug 6, 2015 04:15 AM
