break-in and EOS
Old Aug 4, 2008 | 09:35 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
break-in and EOS
I know it's needed for a flat tappet break-in, but is there any benefit using EOS for a roller motor break-in? This is for a ZZ4. I read in the GMPP catalog that it should be used during break-in with all of their new cams regardless of tappet design. But the break-in procedure for my motor doesn't mention it. It says to just use 10w30 conventional. any thoughts? Thanks.
Old Aug 4, 2008 | 04:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: break-in and EOS
It's probably similar to the reason why the shampoo bottle says "Lather, rinse and repeat.
Old Aug 5, 2008 | 01:49 PM
Engine: 5.7, 5.0
think I'll use it anyways.......unless anyone can think of a good reason not to?
Old Aug 5, 2008 | 02:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Waste of money?
johnsonm
Mar 2, 2007 02:17 PM
MikeDirntRulez
Jun 10, 2006 09:19 PM
zz17iroc
Nov 10, 2005 07:34 AM
PhLaXuS
Car Audio
Sep 21, 2005 08:14 PM
