Torque arm mount for T5 info
Old Aug 11, 2008 | 11:58 PM
Bo1226's Avatar
Car: 83 Z28 modified 350
Can someone tell me if there are more than one style of rear torque arm mount for a T5 trans? If so how do I know which one I need? I'm building a 86 Iroc w/350 carbed. I done a manual swap so dont know what year trans is out of. I guess I'm hoping that the torque arm for 700R is the same as T5. Any info would be appreciated.
Old Aug 12, 2008 | 06:35 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Re: Torque arm mount for T5 info
The "rear mount" is simply two bolts that attach it to the differential. The front TA bushing has 2 possibilities; you need to look at the metal case around the bushing, check to see if the steel lip faces the driveshaft or away from the driveshaft.
When you order new, get the poly one. Hell, do the trans mount while you're down there for a few bills more.
Bubbajones_ya
Jul 6, 2024 08:32 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
