code 12
Old Nov 2, 2008 | 05:44 PM
rock861261's Avatar
code 12
i get code 12 constantly only code 12 will blink and blink past the 3 times i can get my car to idle but not rev or rev very slowly and ideas how to fix this code 12?
91 camaro l98 tpi
Old Nov 2, 2008 | 06:00 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
Re: code 12
ive always heard that code 12 is normal and that means the system is operating properly.
Old Nov 2, 2008 | 06:02 PM
rock861261's Avatar
Re: code 12
but not after 3 blinks its suppose to be something with the dizzy
Old Nov 2, 2008 | 06:03 PM
Daves03's Avatar
Engine: 305 V8 TBI
Re: code 12
is it not displaying anything after the code 12
Old Nov 2, 2008 | 06:05 PM
rock861261's Avatar
Re: code 12
thats it constantly code 12 if i reset the ecu it pops right back up code 12
Old Nov 2, 2008 | 06:06 PM
Daves03's Avatar
Engine: 305 V8 TBI
Re: code 12
the codes displayed by the check engine light are basic diagnostic codes there is a code 12 to indicate you are in the diagnostic mode then the active codes then a code 12 to close the communication, if the code your looking for is not comming up you may need a scan tool to look deeper into the diagnostics.
Old Nov 2, 2008 | 06:08 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: code 12
Normal. It just means it's not running.
Old Nov 2, 2008 | 06:10 PM
rock861261's Avatar
Re: code 12
any ideas on my problem cant go below 1000 rpms when timing and reves really show
Old Nov 2, 2008 | 06:11 PM
Daves03's Avatar
Engine: 305 V8 TBI
Re: code 12
plus you say after the code 12 is displayed you can rev the car you are not trying to run the car with the pins grounded out are you, i did by accident and it made my car absolutely FREAK.(it hated that)
rock861261's Avatar
Re: code 12
then why do i have acheck engine light on
no i cant rev the car period and no just check it when its off
Old Nov 2, 2008 | 06:15 PM
Daves03's Avatar
Engine: 305 V8 TBI
Re: code 12
https://www.thirdgen.org/forums/dfi-...ode+12+running
this should explain it a little better on the second post.
Old Nov 2, 2008 | 06:17 PM
Daves03's Avatar
Engine: 305 V8 TBI
Re: code 12
if you cant rev it period you may have a bad throttle position sensor.
and your timing is set right correct you put a timing light on it.
Old Nov 2, 2008 | 06:19 PM
rock861261's Avatar
Re: code 12
i see but theres a code in there some where my ses light use to shut off before with the key on
if you cant rev it period you may have a bad tps sensor.
real slow rev and i had no problems until 2 days ago when i swapped the intake after that can get it going
Old Nov 2, 2008 | 06:22 PM
Daves03's Avatar
Engine: 305 V8 TBI
Re: code 12
double check to be sure nothing was left unplugged or it was pulled loose when you pulled the intake, i know every chevy ive seen with obd1 the light dosent go off untill the engine is started because the computer throws the code that states its not receiving the pulses from the distributor which means the car is not running. the code thrown is code 12 now if code 12 is being thrown while the engine is running that means the distributor is not sending the signal to the ecm that the engine is running which i think its controled by the ICM or the ignition control module.
Old Nov 2, 2008 | 06:24 PM
rock861261's Avatar
Re: code 12
i checked everything
no the light stays solid then goes out after about 5 seconds
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
