Cam Question
Old Nov 29, 2008 | 02:17 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Cam Question
I know nothing much about cams, and I bought a '88 T/A and it's cammed. The last owner doesn't know the specs and he never tuned the computer so he says the cam doesn't know what to do.
I want to tune the car but if I don't know the specs, should I just put a stock cam or splurge and buy a cam for the car that I know the specs for?
I don't want to get a tune for the car but still have the car out of whack.
The car is not a DD.
Old Nov 29, 2008 | 02:23 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: Cam Question
if you take it to a good shop to get it tuned they'll put it on a dyno and hook it up to a wideband. They don't need to know your cam specs, the dyno will give them all the info they need to get optimal power out of it.
Old Nov 29, 2008 | 02:33 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: Cam Question
I was talking about if you were to learn how to tune and do it yourself.
Old Nov 29, 2008 | 03:10 PM
Car: '89 IROC-Z
Re: Cam Question
To tune it properly you'd still need both things I mentioned: dyno and wideband. You don't need your cam specs, you just need to find out what A/F ratio and timing your motor likes by experimenting.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
