Headlight motor problem...
Old Dec 17, 2008 | 10:00 AM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
My right headlight motor works, but when I shut it off it makes a loud clicking? noise while turning, it last for about 5 seconds. It is fairly loud, and also twice the headlight would not go up when I turned them on. Its getting cold in my area so I dont know if that could have something to do with it. Thanks
Old Dec 17, 2008 | 09:43 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: Headlight motor problem...
In the reducer, there are 3 nylon bushings. They wear out. You can get some off Ebay, or else in a pinch, the Ford window motor bushings are also the same size. I'd try pulling the headlight assembly, pull off the motor and check those. There are some write-ups out there that guide you through it. If not for a Firebird, try searching for the same repair on a Fiero since they use the same motors.
Old Dec 18, 2008 | 10:46 AM
Sly_dawg19's Avatar
I replaced my bushings with cut hot glue sticks, no problem as of yet Well see when summer hits though
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
LittleFranks
Sep 17, 2015 12:22 PM
stalkier
Aug 13, 2015 12:59 PM
