blower motor out?
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
blower motor out?
i was turning on my a/c the other day and the switch got stuck and felt like it broke internally, so i went to the junk yard and pulled the whole control module (very carefully) and just replaced it in my car. and the blower wont turn on, the a/c compressor clicks when i push it to the a/c side but no blower turns on.. any ideas i was ganna go and get a relay but wanted to check see if any else had the same prob. thanks
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
THIS IS ALL HOT AIR
If the blower motor worked immediately before the swap, the replacement HVAC controller probably has a malfunction.
Because you got one from the junkyard chances are you swapped a bad for a bad.
Check the HVAC controller with an ohmmeter.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Street Lethal
Aug 13, 2015 08:28 PM
