do adding heads help HP?
Old Jan 4, 2009 | 02:43 PM
scoutsniper's Avatar
Car: 2000 TRANS AM
Engine: H,C,I LS1
Axle/Gears: 3.42 posi
hi. my freinds got a 1991 camaro rs with a 305 carbed motor. he was wondering if adding 2.02 by 1.60 with 67cc chamber heads would help at all?
thanks
Old Jan 4, 2009 | 02:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: do adding heads help HP?
Depends which heads they are. 2.02 valves are generally too big for a 305.
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I'm thinking that will probably hurt performance or not do much for it. First off with those size valves you can only go up to .450" lift and the valves are shrouded anyways. They might flow more air to make more power, but I believe 305 heads use a 58cc combustion chamber so it will be losing a large bit of compression.
Old Jan 4, 2009 | 06:21 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
I heard you can't use 2.02 heads on a 305, something about the valves hitting the cylinder walls?
Old Jan 4, 2009 | 07:27 PM
Car: 2000 TRANS AM
Engine: H,C,I LS1
what about a 350ci?
Old Jan 4, 2009 | 07:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
2.02 valves on a 350 are fine, but again it depends what heads they are to know if they're worth it.
gta90
Sep 15, 2015 04:00 PM
509 camaro fan
Sep 6, 2015 10:43 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
mizz0313
Aug 12, 2015 06:45 AM
