1.6 Roller Rocker Question
Old Feb 2, 2009 | 04:33 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
By putting 1.6 ratio roller rockers on my engine along with my cam (.444/.444 lift), will my motor be able to handle this much lift. It is a 305.
Old Feb 2, 2009 | 04:55 PM
David 91RS/Z28's Avatar
Re: 1.6 Roller Rocker Question
You will add roughly .030" more valve lift which will increase your overall lift to .474ish. P to V clearance should be fine. I hope you have upgraded your springs already, if not you need some. You didn't really say anything else about your setup, but the rockers should add a bit more power.
Old Feb 2, 2009 | 05:11 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
What other mods do you have? I would say that the 474" lift that David described is too much lift if you don't have mods to support it. If you have bone stock 305 heads(no porting), stock cat back and no headers, 474" of lift is a waste. Think of your motor is just a glorified air pump. If you try to cramp more air in but don't give it an equal opportunity to get air out, you won't get the result your looking for.
Old Feb 2, 2009 | 07:06 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I have a Comp Cams (260/260 dur. .444/.444" lift, 112 LSA), Hooker 2460's and Y-pipe, Flowmaster 80 series, a BBK AFPR, and a burned Prom. I did upgrade the springs with the ones that they recommended with the cam. So I wont have to worry about clearance issues then?
Old Feb 2, 2009 | 08:43 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Unless you altered the installed height from stock, the problem is not the valve springs. It's the height of the entire assembly in relation to the top of the guide boss. The bottom of the retainer will hit the guide boss preventing any further lift.
Old Feb 2, 2009 | 09:07 PM
wesilva's Avatar
Transmission: 200R4
Also check the pushrod clearance as it passes through the head. About half the factory iron heads I've seen need a little more clearance.
Old Feb 3, 2009 | 07:38 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Can anybody for sure tell me if i'll have enough clearance or not?
Old Feb 3, 2009 | 10:18 AM
It's always good practice to check engine clearances yourself instead of relying on outside information. Check the clearance you have now so you will now for sure if you will have any issues.
Old Feb 3, 2009 | 11:43 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
How would I check my clearance to see if I can use them?
Old Feb 3, 2009 | 12:02 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
You would either have to disassemble the valve spring assembly and measure with a valve spring micrometer or caliper, or get a 1.6 arm and checking springs and trial fit them. Remember, you need a little bit of safety clearance on top of the required lift clearance.
I would check all 16 for clearance.
midge54
Dec 27, 2019 04:14 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
