compression testing
Old Feb 8, 2009 | 02:46 PM
fychelio's Avatar
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
compression testing
will it tell you if all the valves are properly opening and closing if all cylinders have the same compression?
Old Feb 8, 2009 | 03:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: compression testing
Compression test tells you how much pressure is being built up inside the cylinders. All the cylinders should be within a few percent of each other. If all are equally low then the engine is wearing evenly. How much pressure is made depends on a lot of factors including valve grind.
If a problem is suspected then a leakdown test should be performed to determine the cause of the lower pressure.
Excess air escaping into the crankcase normally means worn rings but could also indicate a damaged piston, cylinder or head gasket. Air escaping out the intake indicates worn intake valves. Air escaping out the exhaust indicates worn exhaust valves. Bubbles in the coolant normally means a bad head gasket but could also be a cracked head or block.
To know if the valves are opening and closing properly, the valve covers need to be removed and the rockers visually inspected while the engine is being cranked over. A rocker barely moving will indicate a worn cam lobe.
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
