injector's with 5.0 combo?
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
hi guys..im in the middle of building(at the shop) my 305 for my 88iroc...they have most of the motor together...but my problem is im not sure what size/brand injectors to use?
trickflow 56cc 175
comp cams roller 218/224 at 50 - 502/495 lift
Holley stealth ram intake
stock displacement 5.0
thx bill
trickflow 56cc 175
thx bill
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: injector's with 5.0 combo?
Go with the 24lbs. Call Jon at FIC, he can hook you up with a set of Bosch Design 3 with modified bases to fit the TPI. I know he offers them because I asked him when I was buying mine, but decided to go with the 22s for my application.
And yes, you will need to get it tuned.
Car: 89 Formy
Transmission: A4
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
ya they will fit, but some people say you need to buy the gm o-rings for the injector to get them to seal right, i used the ford o-rings that came with mine on 3 differerent camaros and never had a problem, but others had different experiences, just something to think/search about.
Car: 89 Formy
Transmission: A4
thx!
if i ever decide to go with a higher lift cam(around 560/570)...would the 24lbs be ok?
Car: 91 Z28
ya they will be fine, but you will need to tune it again. im surprised you went with such a small duration cam with using the holley stealth ram intake.
Car: 1983 G20 Chevy
Transmission: 4L60
