Engine Rust
Old Mar 14, 2009 | 02:20 AM
reese_galmon's Avatar
Car: 1990 Firebird Formula 350
Transmission: 700-r4
Engine Rust
I have some heavy rust on my engine and i was wondering if theirs any king of rust spray i can use to get the rust of and i also have a little on da body
Old Mar 14, 2009 | 10:46 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Engine Rust
heavy rust? probably not. Where, exactly, on the engine?
Old Mar 14, 2009 | 12:19 PM
Re: Engine Rust
its on the bottom of the engine around the exhaust headers
Old Mar 14, 2009 | 12:35 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Engine Rust
Unless you have a coolant leak, there's no good reason you can't just ignore it.
Old Mar 14, 2009 | 12:46 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Re: Engine Rust
I agree with Atilla ^. If the rust isnt interfering with the engine ie: on cylinder bores or plugging water jackets, then you wont gain anything (aside from asthetics) by removing it. Rust on the exterior of engine block poses no risk as it would take hundreds of years for rust to penetrate. If you're dead set on removal , the most comprehensive method is to tear the engine apart, down to the bare block, then have it hot tanked and bead-blasted, then rebuilt of course.
-Zander
Old Mar 14, 2009 | 04:04 PM
Re: Engine Rust
ok cool thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
