Silly Timing question...
Old Mar 15, 2009 | 12:42 AM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
So the car is a 92 z28 originally 305 but has a 350 in it with the 193 heads (caprice) TPI etc. Should the timing be 6* or should it be the same as the Caprice? right now i have it at 6*, but on a cold motor it backfires when shifting out of first/second. When it warms up it is ok, but i have a small misfire at idle... could this be caused by the timing being at 6*?
Old Mar 15, 2009 | 12:51 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you do anything different with the computer? MAP or speed density systems don't take well to displacement increases without retuning.
Old Mar 15, 2009 | 02:00 AM
boldguy's Avatar
Car: 1992 Z28
Re: Silly Timing question...
I tuned the computer with the following:
-Changed the volume per cylinder
-changed the injector flow rate (22 lbs Bosch design III's)
-changed all VE tables to that of the AUJP's... (didn't know if that was the right thing to do...)
Old Mar 15, 2009 | 09:35 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The TPI computer wants the timing at 6 degrees. That's what's important.
You'll need to do a datalog and figure out if the engine is too rich or too lean when its cold, and adjust the tables accordingly.
Old Mar 16, 2009 | 12:36 AM
boldguy's Avatar
Car: 1992 Z28
Thanks kevin.
I think i'll check out each header pipe with an infrared temp gun...
In your guys opinions, is changing the VE tables to the AUJP ones a decent move? (different heads than the L98...) the car doesnt backfire when cold anymore.... but it will idle pretty high when im coming to a stoplight and stay at around 1200 until i come to a complete stop...
bamaboy0323
Sep 3, 2015 06:07 AM
happyhapka
Aug 15, 2015 04:42 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
