Zero Spark??
Old Apr 8, 2009 | 06:31 PM
BloodyBlueBird's Avatar
Car: 86' Firebird
Engine: 350 c.i. swap
Transmission: G-Force T5
Zero Spark??
One morning I went out to start my car, and when I tried it would just crank but not turn over. I wasn't getting any spark at all . It started the day before and many before that. I just put on a new distributor cap, module, rotor, and wire harness. I thought I screwed something up while installing something . I have a spare distributor and after I put that on I still had the same problem . I checked the spark plugs and even changed over the wires with some spare ones. The knock sensor has some damage to it when I was putting on my headers . It may be having some connection problems. could this cause the lack of spark??
Some background info that you need to know:
its a swapped 350
HEI PerTronix Flame-Throwerdistributor
600 cfm Edelbrock performer carb
Old Apr 8, 2009 | 09:07 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Zero Spark??
No, the knock sensor won't keep it from firing. If you swapped the dist, that only leaves the wiring and the ECM. You might want to clean and tighten the grounds on the back of the passenger head and make sure your ECM has power. Does the CEL light come on when you turn on the ignition?
Old Apr 8, 2009 | 09:21 PM
Car: 86' Firebird
Re: Zero Spark??
when I did the engine swap i tore out the ECM, so it is no longer computer controlled. I hooked up a voltmeter to check if i was getting power to the distributor itself and it is getting power. I'm stumped
Old Apr 8, 2009 | 11:14 PM
Car: 86' Firebird
Re: Zero Spark??
Anyone have any more suggestions?? I can't figure this out.
Old Apr 9, 2009 | 07:21 PM
Car: 86' Firebird
Re: Zero Spark??
Still looking for any suggestions or input... any help at all would be greatly appreciated.
I went out today and found that the timing was way off. I'm not sure how that happened, but it should get spark through the wires still right??
Again, any help would be greatly appreciated
Old Apr 9, 2009 | 09:43 PM
Prickly's Avatar
Car: 88 Formula
Engine: E code, what else is there ??
Transmission: 700R4 stock
Axle/Gears: Stock w/ limited slip
Re: Zero Spark??
If the timing is too far off you will be sending spark to the wrong locations at the wrong time. If your timing is suspect which sounds like a probable cause, start fresh with TDC. You didnt mention the ignition coil, I assumed only the distributor was checked and replaced. GL
Old Apr 9, 2009 | 10:25 PM
Car: 86' Firebird
Re: Zero Spark??
Yeah the coil is new, and I will be checking to see if it was the timing tomorrow when my battery charges back up. thanks for the input
Old Apr 10, 2009 | 08:17 AM
50bmgshooter's Avatar
Re: Zero Spark??
I just had a brand new msd blaster coil fail on me. 2 weeks old and about 100 miles on it
you might want to try a known good one in the car.
Old Apr 10, 2009 | 01:33 PM
Car: 86' Firebird
Re: Zero Spark??
Yeah I used the old coil that I had on before that worked. I reset the timing today and still nothing... maybe both pickup coils are gone. very unlikely but who knows. How are some of the ways you can damage the pickup coil other then it just shorting out?? maybe while installing the modules I did something... I'm going to setup the voltmeter today to test EVERYTHING again. I hope I just missed something before.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
