code 43/ esc
Old Apr 15, 2009 | 12:40 PM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
code 43/ esc
my 89 RS 305 is producing a code 43. i replaced the knock sensor, it didnt appear to be working when i tested it, but it could be that my inexpensive volt meter isnt sensitive enough to pick up the voltage when i taped the block. now im thinking that the electronic spark control could be at fault. i did test that, and i get voltage at the wire being fed from the key switch, the wire going to the ecm, and the wire going to the knock sensor. my stepfather has an old rotted out s10 blazer with a 4.3L Z code engine(junk truck). is the electronic spark control the same? i know its a v6, are they calibrated differently or something? i dont really feel like spending 70 bucks on a part like that. i was thinking of looking the in junk yard for one as well.
Old Apr 15, 2009 | 10:47 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: code 43/ esc
What are some of your readings from the wires at the ecm and at the ESC?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
