dipstick question
Old May 31, 2009 | 12:11 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
dipstick question
Ok I'm installing my 2460 headers today and took the dipstick out to get the passenger side in. The dipstick tube actually slide right out with no effort. My question is since it's a "press fit" should I enlarge the end of the tube so it stays in there? Seems like its going to work its way out especially since I dont see a bracket to secure it to unless I make one. thanks
Old May 31, 2009 | 01:07 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: dipstick question
Is it possible it was not fully pressed in?
Old May 31, 2009 | 01:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could ream the tube a little larger, or ever so slightly flatten the end a bit.
Old May 31, 2009 | 03:06 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
It presses in all the way up to the lip, I was just expecting a tighter fit
Old May 31, 2009 | 05:39 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Ok I've tried getting pressing this thing from all different angle and its still sloppy, is this the norm?
Old Jun 2, 2009 | 12:23 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I will check mine today, I believe mine moved a good 1/2" each way. Ill double check and let you know, maybe make a short video to show how mine is (and without leaks around it)
maroe624
Apr 16, 2017 08:29 AM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
