Head Swap ???
Old Jun 1, 2009 | 01:09 PM
dieseldust's Avatar
Car: 1989 Firebird
Head Swap ???
Hello,
I have a 1978, 350/4 barrel /T350, i have some bolt on items already i want to put on, Headers /750 holley, Holley Dominator Intake, dual 2.5 exaust,and a richmond gear set 456. My question is would this all work with the heads listed below , they where built for propane, i dont think that matters does it.
These heads are the Camaro TPI HO 305 Heads, casting# 187, 58cc.
The intake valves have been properly upsized to 1.94" (they were 1.87"), exhaust is stock 1.5". Planed and clean, ported and polished.
Isky Valve springs (part # 205-D), umbrella style valve seals.
These heads have been fully rebuilt with hardened seats installed to run with Propane, stock rotators removed from the exhaust valves. All work has been professionally done.
Thanks in advance
James
Old Jun 1, 2009 | 01:20 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Head Swap ???
You will raise your compression ratio up, and probably need to run 91 fuel
Most 350's start with 64 CC
Old Jun 1, 2009 | 01:35 PM
dieseldust's Avatar
Car: 1989 Firebird
Re: Head Swap ???
I can live with high octaine gas but do you think it will be a good choice performance wise as far as the heads go on my 350 with those bolt ons as listed.
James
Old Jun 1, 2009 | 01:41 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: Head Swap ???
With the work done i don't see a problem with flow rates, i know there are some really smart guys on here that know a abundant of information about heads, hopefully they can chime in and give ya some pointers. I would put them on, but thats me. From what ive looked up in the past few minutes, should be a decent setup
Old Jun 1, 2009 | 01:44 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: Head Swap ???
Do keep in mind with these heads, they are from the 305 tbi motor, and are swirl ports. Make tons of power up to 4500 rpms, after that, its no go :/
Tpi heads have a castings of like 601 and such.
Old Jun 1, 2009 | 01:48 PM
dieseldust's Avatar
Car: 1989 Firebird
Re: Head Swap ???
Thanks for your imput Rough,
Hopefully some of those Really Smart Guys, will speak up, i am not a pro on this one lolololo i know this site has got some of the best advise around and thank all in advance.
Cheers
James
Old Jun 1, 2009 | 01:51 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Head Swap ???
To put those swirl-port heads on a 350 is a great way to make the engine run out of breath above 4000 rpm, whatever the cam.
Old Jun 1, 2009 | 01:52 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Head Swap ???
Oh, another thing, your intake won't match up with the 187 heads.
Old Jun 1, 2009 | 01:55 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: Head Swap ???
Didnt notice the intake mismatch nice catch Atilla
Old Jun 1, 2009 | 02:03 PM
dieseldust's Avatar
Car: 1989 Firebird
Re: Head Swap ???
Oh well back to want adds, lolol i would like to use what i have for the bolt on items, maybe just get my heads done up, dont know the casting numbers only know its the original 1978 350 4 barrel engine.?????
James
Old Jun 1, 2009 | 02:05 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: Head Swap ???
If it aint one thing its another huh ?
If i new anything about carbs, id look for a intake for you, but i know nothing about carbs :/
Old Jun 1, 2009 | 02:40 PM
dieseldust's Avatar
Car: 1989 Firebird
Re: Head Swap ???
lolol that makes 2 of us Rough,,, well i am sure some one may know about the heads i have on my stock 78 and maybe just get them redone and matched to the intake .
James
xkingcodex
Feb 12, 2020 07:43 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
