Oil pressure problem (as in no pressure!)
Old Jun 29, 2009 | 09:20 AM
L98FORM89's Avatar
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
OK guys here's the story :
Drove the car one day, was running fine,albeit with a little exhaust header leak. Anyway, next day I started the car and it had loud tapping noise from the engine. I looked down and saw NO oil pressure, it normally runs 45-60. Pulled the valve covers it looked pretty dry. So I pulled the distributor and put a drill down in to spin the oil pump and could only barely get any oil out of the rocker arms, some of the lifters werent even pumped up.
Some quick history 355 rebuilt 4000 miles ago, with a new Melling pump and a high pressure spring, tack welded pickup, 6 quart Moroso pan.Oil was changed a few hundred miles ago.
Have had no oil issues before or since the rebuild until now of course.
Any ideas would be greatly appreciated. Thanks Stewart
Old Jun 29, 2009 | 03:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Oil pressure problem (as in no pressure!)
Not trying to be a smarta$$, but you didn't mention - it's full of oil?
Old Jun 30, 2009 | 09:29 AM
L98FORM89's Avatar
Engine: 355 HSR
Yeah and no leaks either.
Old Jun 30, 2009 | 12:47 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
how old is the pump? was it replaced with the rebuild?
Old Jun 30, 2009 | 01:41 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Sounds like you need to take the pan off and see if anything is obstructing the oil pump. If it's clear, you could have a bad pump, worst case scenario is your main bearings are wiped.
Old Jul 2, 2009 | 01:15 PM
L98FORM89's Avatar
Engine: 355 HSR
Brand new Melling M-55 with a high pressure spring, I am afraid the tack weld on the pickup broke and its laying in my oilpan.
Old Jul 2, 2009 | 09:27 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
That would be my guess. Hope it didn't run for long that way.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
92camaroJoe
Aug 13, 2015 06:07 AM
