84 Berlinetta
Old Jul 1, 2009 | 02:30 PM
DonSSDD's Avatar
84 Berlinetta
Friend has one, 305 4 barrel, works fine at up to 50 mph, will run without a problem. When he drives it on the highway at say 60-70mph, it quits. It will restart if you turn the key off and then you can run it a while up to 100mph, then after a bit, it quits again.
Digital dash, all original car with 100,000 or so miles. Canadian car if that makes any difference.
The fact it restarts must mean a sensor somewhere? Do they have many or a computer?
Thanks for any replies.
Don
Old Jul 1, 2009 | 06:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Electrical, yes. Sensor, probably not (most Canadian-delivered base V8 3rd gens weren't computer controlled, hence no sensors, making it extremely unlikely). More likely something in the ignition - power wire (pretty common), ignition module (pretty common), or coil (pretty common, often accompanies ignition module).
100 MPH, eh? I assume this isn't the German autobahn.
Old Jul 1, 2009 | 06:43 PM
DonSSDD's Avatar
Re: 84 Berlinetta
Thanks, that's 140KPH in Canadian.
Don
Lbibb
May 5, 2016 12:00 AM
Linson
Oct 1, 2015 09:50 PM
rusty vango
Sep 29, 2015 02:44 PM
RacerM
Sep 28, 2015 04:25 PM
manifoldsrme
Sep 17, 2015 11:40 PM
