getting a build started
Car: 1991 Camaro RS
Engine: 305 TBI
well my L03 runs great,but its getting up there in miles and not getting any newer. so im bout to start bulding a fresh 305(so please no swap in a 350 talk).
so whats the best engine to build on(ialso know a machine shop that will be helping me through this,but needing little 3rd gen help to getting a parts list together)...
would a 305HO out of a MC SS be good start?
i thinking bout boring .060 over,i know the 305 have a small bore stock,but are the walls thick anough to take that?
as for heads im thinking bout hot rodding some HO heads,or should i go up to a L98 or LT1 head?
this will also be a carb motor
my goal is to try and put down 300whp all motor
so any advice,will deff be welcomed.
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Re: getting a build started
if you bore out a 305 it will be close to a 350. Y not start with something larger and only bore/hone out .010". You can use your crank you have now and your rods. all you need is larger bore pistons.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You don't bore motors for performance reasons. You won't notice anything performance-wise from any overbore. Boring a 305 a even to the "max" of .060" only yields 315cid, which is nothing close to 350.
I agree with five7.
Kind of pointless to pull a 305, and put a 305 back in, especially if you're going to end up buying the short block or longblock, whatever it may be.
I agree with five7.
