Engine casting numbers
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
I have a 84 Trans am. I have just pulled the motor wich is not the oragnal one for the car. The casting numbers on the block are 3932386. The numbers on the heads are 3932454. If any one know what motor these numbers are for will help alot.. Thanks
Transmission: 4L80E/4L80E
http://www.mortec.com/castnum.htm
Block:
3932386....302.....69....4...Z-28 Camaro
3932386....327.....69....2
3932386....350.....69....2 or 4
Heads:
3932454....69-73...307
3932454....69-79...350..........Truck
If the block and heads have always been together, it's a '69 truck 350. If not, at least the heads are truck 350, most likely from the 70's.
Figure on the heads being performance junk. The blocks were known to have casting & machining problems (lifter bores not properly lined up to the cam, starter bolts not properly placed, core shift). If it ran okay and doesn't have any weird wear evident, it's probably okay for rebuilding (if the bores aren't already 0.060"-over).
Block:
Heads:
Axle/Gears: stock
Re: Engine casting numbers
Dont know if the heads and block have always been together. Bought the car this way. Are there any way to know what block it is if the heads was put on at a latter date. or if they have always been together/
You might get some hint by the numbers that are stamped on the block pad in front of the passenger side head.
Measure the cylinder bores - if more than 4.000", it's been rebuilt.
Check the crank casting #. If it's a 327 crank, it wasn't delivered with the heads. If it's a 302 crank, somebody did a very untoward thing to a valuable engine.
Axle/Gears: stock
Ok I got home and pulled the oil pan. The crank #s are 3932442. I think it is a 4 Blot main no sure if the front and rear are also 4 blots or if it is just the center ones. I think like the center 3-4 are 4 bolts. But the firts and last are just 2. Just trying to firger out what i have and if it is a good start for a rebuild.
Axle/Gears: stock
any one??
From www.mortec.com:
3932442..267,305,350..cast...medium journal...3.48" stroke
It's a 350.
A "4-bolt" only has 4 bolts on the center three main bearing caps.
It's a 350.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Axle/Gears: stock
I have jjust got the numbers off the front of the block at the pass side head. They are;
V0917WK
That is the only ones there. Hope some one knows what they mean
V0917WK
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
