engine cuts out
Old Jul 26, 2009 | 02:21 AM
89Limited's Avatar
Car: 89 Bandit, 88 formula, 87 Trans Am
Engine: 305 ho, 355, 305
Transmission: 700r4, th350 (2000stall), 700r4
Axle/Gears: 2.73, 3.73, 3.73
engine cuts out
i just recently put another 305 in my 91 RS, cause the other was toast. with this motor in, anything above 3 grand or so, it starts cuttin out and hesitating really bad. almost like its not gettin enough fuel, or maybe even the timing is a little off. i have replaced the coil, fuel filter, new plugs, new wires, i believe i installed a new cap and button, also have removed the smog pump and related hardware upon slipping this engine in. i still have my egr valve (which could prove to be a bad one) it stil has the factory TBI. sometimes after i start it up, it misses real bad till it gets warmed up, especially after a good rain (it has a cowl induction hood). im grasping at straws. am trying to hold off on going carb till the motor on the stand is done. i just would like to be able to joyfully drive my maro again.
Any ideas???
Old Jul 29, 2009 | 01:16 AM
89Limited's Avatar
Re: engine cuts out
any one?
Terrell351
Jun 13, 2021 01:13 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
