Is this how my car should be acting
Old Aug 19, 2009 | 07:30 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I wasn’t really sure if this is the place to post this question, so if its not, I apologize.
I just got my car about a month ago (1988 Iroc, 350, 3.27, all orig., 75K miles) I still have to fix the running rich problem, the maf sensor code (34) I’m getting, and check the cat, i think it may be clogged.
My question is, when at a stop if I punch it, I only get like a "squeak" from the tires. I’m thinking my car doesn’t have the pickup it should.
Is it just me, or is there something wrong with my car.
Old Aug 19, 2009 | 09:52 AM
KnottyBuoyz's Avatar
Car: 87 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Not sure, gotta look it up
Re: Is this how my car should be acting
Definitely something wrong. Mine's an '87 with 100K more miles on it than yours and I can light them up w/o any problems.
I've been troubleshooting a code 33 so I feel your pain. 34 IIRC is a low voltage signal from the MAF so check and clean all your connections. There's a number of troubleshooting guides on here. Follow them. Don't go throwing parts at it like I did. Don't ask.
Good luck.
Old Aug 19, 2009 | 10:27 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Thanks for the reply man. Im working on getting it running perfect. I thought something might be wrong, and I hope that once I get it to run a little leaner and fix the MAF problem it will run the way its suppose to.
Ghettobird52
Jul 5, 2024 11:18 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
