SD Vortec head on TPI - where to install knock and temp sensors?
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
Does it matter where I install the sensors into the head? Are the head sensor locations the same as the L98 heads?
I've been running my vortec tpi setup a while now and my knock sensor needed replacing. When I removed it I found out it was in a coolant passageway. Is that right?
thanks
thanks
Car: 89 GTA
Transmission: 7004R
Re: SD Vortec head on TPI - where to install knock and temp sensors?
Just realized the knock sensor is actually in the block, so i guess all the sensors go in the same place as vortec heads.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
