False High RPM
Old Aug 29, 2009 | 07:14 AM
OddJack's Avatar
False High RPM
My 89 camaro shows idling at 5000. I recently changed caps and rotor and changed wires. Changed the battery also. Any idea how to fix?
Old Sep 27, 2009 | 06:24 PM
OddJack's Avatar
Re: False High RPM
Still not fixed...anyone ever had this problem?
Old Sep 27, 2009 | 07:04 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: False High RPM
i am having that problem with my 91 RS it's showing 2500rpm at idle
Old Sep 27, 2009 | 07:32 PM
OddJack's Avatar
Re: False High RPM
Your solution is here, well, maybe:
https://www.thirdgen.org/forums/elec...meter-fix.html
Mine is 89 so a little bit different.
I am thinking the capacitor is good, but since I changed the cap and rotor and put an MSD it is cousing the problem. I now have to try: first change the cap and rotor to another brand, maybe ac delco., then maybe swap the tach if it didnt work.
Old Sep 27, 2009 | 07:39 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: False High RPM
Yeah, it's just an inaccurate tach. Fix the tach or get an aftermarket one.
Old Sep 28, 2009 | 01:00 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: False High RPM
Hate to tell you this, but our tachometers are notoriously inaccurate. You'll have better luck in the electronics board if you want a solution though, try a search. I've seen many threads on it. Or like he ^^^ said, an aftermarket tach is a simple "solution" as well, if you're not a stock ****
Old Sep 28, 2009 | 10:16 PM
OddJack's Avatar
Re: False High RPM
Swaped the tach, problem solved. Found a used one from a guy who was parting out his camaro.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
