need question answered fast !
Old Oct 22, 2009 | 12:43 AM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
my car ran real rich due to an eshaust leak fixed it but still running rich but not as much , could my oxygen sensor have gone bad since i was running it when it ran super rich ? and also im getting a code 42 " ESC module" anyone know how to fix that on an 88 lo3?
Old Oct 22, 2009 | 12:50 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: need question answered fast !
i do know o2 sensors can't take much abuse. So it could be faultered. on for the module i don't have mine hooked up its carb'd don't knwo much about that.
Old Oct 22, 2009 | 02:02 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
check and see if your knock sensor is even plugged in. an open in the knock sensor to ecm circuit can throw code 42. it happened to my 92 rs.
Old Oct 22, 2009 | 10:53 PM
ok i will check that , but also the black and gray connectors that clip onto my ignition coil are broken and become loose from time to tim , can this be setting off a code 42?
Fast355
Dec 2, 2016 06:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
