Power Steering Pump Removal HELP
Old Oct 25, 2009 | 12:04 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Hey guys i have 1991 formula firebird with a 305 in it all stock. I am trying to remove the power steering pump... I need Help or some advice on to pull this out w/o breaking it. Its a pain in the you know what. I have a bolt behind the power steering pump itself THATS those darn hex screws. I mean come on. I NEED HELP. I pulled most of the bolts off and just need this one bolt behind the power steering pump if any of you ever pulled one of these off before suggestions ASAP please.
Old Oct 25, 2009 | 12:21 PM
berlin305's Avatar
Re: Power Steering Pump Removal HELP
BUMP PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!
Old Oct 25, 2009 | 12:37 PM
berlin305's Avatar
Anyone up for suggestions Please need help.
Old Oct 25, 2009 | 12:46 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
you need a power steering pump pulley remover. you need to pull off the pulley while the pump is still in the car. you can then access the bolts that hold it to the bracket. i dunno if you can rent this at the parts house or not. you need this puller. and to make things funner for you, you will need to procure the pulley installer as well. i think a crude version of the installer will be included in the box with the new ps pump.
Old Oct 25, 2009 | 02:24 PM
berlin305's Avatar
Thanks for the info on that. Thankfully i am not taking the power steering off the bracket was just trying to get it off the engine as whole. I found out how to do it WHAT A PITA. I will never ever pull another one. I will stick to my older engine with the steering pump 3 bolts and out. and there bolts LOL not those damn hex bolts.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
