Code 15 Trouble Code
Old Oct 26, 2009 | 01:21 PM
Garcia742a's Avatar
Engine: 305 CARB
Hey to all,
So I just got an 85 z28 carb and it needs a little work but no big deal so I had a check engine light and went and bought the code reader(stupid didnt' know about paper clip) and pulled codes 14 and 15 so I check the cts and its not even connected the pigtail is broke the wires are touching and the top of the cts is broke. so I put on a new pigtail and reset the ecm. went and bought a new cts put it in a day or 2 later and the engine light came back on w only a 15. I am new to automotive work and need help. Any ideas? do I just reset the ecm again cus I had reset it before changing the cts?
Old Oct 26, 2009 | 04:19 PM
dirtyd6669's Avatar
Car: 87 Trans Am
Re: Code 15 Trouble Code
try reseting the ecm again and if that dont work then you need to follow the wires and make sure they werent damaged anywhere else
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
