What is this?
Old Jan 20, 2010 | 07:02 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
What is this?
I got an 1988 camaro RS V6 i was looking around seeing what was loose under the hood and i found this.
It connects from the back of the air intake splits into two. one heading to the break booster and the other leading to this host that broke off.
it got cocked together and i dont know what calve it connects too.
I just need to know what it is so i can replace it.
The valve is covering in cocking.
And this is what broke off of it.
Old Jan 22, 2010 | 04:17 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: What is this?
Looks like a vacuum elbow that connects 2 hard plastic lines.
Old Jan 22, 2010 | 04:47 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: What is this?
Check valve for the cruise and HVAC vac maybe?
Old Jan 22, 2010 | 06:24 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Re: What is this?
Well ill try. I followes the rest of the line. The thick one leads to the break booster and the smaller one leads to the vapor cotainer
Old Jan 22, 2010 | 11:06 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: What is this?
Hello vetteoz!!
I would say BINGO!! However, it does look like the tapered end of the valve has been shoved into the larger brake booster hose!!
Old Jan 22, 2010 | 11:13 PM
Re: What is this?
Hello Foster382!!
Take a real good look at the valve in vetteoz's picture, and the first one of your's, and you will see that it looks like the tapered end of the valve is inserted into the brake booster hose!! It sure looks like someone broke it, and didn't want to replace it, so they just hooked it up "wrong" as best as they could!!
Old Jan 22, 2010 | 11:43 PM
osso12's Avatar
Car: 85 Z28 Vert
Engine: LG4 ENGINE 5.0 4BBL
Transmission: 700R 4SPD
Axle/Gears: 3:08
Re: What is this?
does your car have a bad miss?
Old Jan 23, 2010 | 11:28 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Re: What is this?
Thanks yal. Thats what i thought with all that cocking on it. It does Miss badly, but it's been happening for so long im use to it. Any of yal know where i can get a replacement for it?
Should it even be hooked up like that?
Old Jan 24, 2010 | 12:22 AM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Re: What is this?
The reason I asked about the miss is because my car was missing badly for about 3 weeks now.. Idled like it had a cam in it...LOL Could not figgure out where the miss was coming from to save my soul...
anyway, that same area as your was broke on mine. I used a t fitting to reconnect the vacum lines... Problem solved. Car purs and idles like a kitten.
Miss completely gone!
Old Jan 24, 2010 | 08:46 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Re: What is this?
osso12, was your break booster hose as thick as mine? Also can yo post a picture of it? i wanna get the correct fitting for it.
Old Jan 24, 2010 | 12:24 PM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Re: What is this?
Its the same setup but I did not do anything spectacular to fix it...
I simply got a vacum tee where the line was broke and spliced.
Old Jan 25, 2010 | 08:20 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Re: What is this?
Sweet it worked. it's not missing anymore
Old Jan 25, 2010 | 11:32 PM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Re: What is this?
Old Jan 26, 2010 | 01:21 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Re: What is this?
I wish just ONCE that something would go this easily for me on mine....... lol
Congrats on the easy fix
