fuel problems on 89 rs
I have an 89 rs with a 2.8 v6 the fuel pump will not come on with the unless you run a hot wire to the Obd pin then it runs. I am getting no power to the fuel pump relay, pump or the fuse by the battery with the key forward any ideas????
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Let’s Light This Fuse
Due to the fact your not getting power past the fuse it’s blown or your not getting power into it.
With a voltmeter probe it back till you find voltage.
Now you’ve located the break.
Happy Racing!
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime
and the nitwits that need headlights for a little rain
If People Drove Any Slower They’d Be Going BackwardsWhen you see fog or “running” lights on in good weather beware. Low performance driver ahead.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
