idle problem when warm
Old Feb 27, 2010 | 06:52 PM
89fireeagle's Avatar
Car: 89 firebird 83 t/a
Engine: 305 tbi
i have a 305 tbi when i start it up in the morning it idles fine. but when it starts to warm up the idle raises and falls till it eventually stalls.
could this be caused by a vacum leak?
Old Feb 27, 2010 | 06:59 PM
jja679's Avatar
Re: idle problem when warm
i have the same problem
Old Feb 27, 2010 | 07:21 PM
Engine: 305 tbi
any ideas? anyone
Old Feb 28, 2010 | 09:10 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The ECM does a few things different once the coolant comes up to temp.
As the time-out fueling decays away, the AFR will go leaner. If you have a vacuum leak, it will cause the most problems once the engine goes lean.
Once at a certain temp the ECM will try to switch into closed-loop operation using feedback from the O2 sensor. If the sensor is bad, or you have an exhaust leak near the sensor, you will notice problems with idle.
Also, at a certain temperature a couple of other functions are triggered that use vacuum lines for actuation. One of them is the EGR system. If a system is malfunctioning or there is an open or broken vacuum line, or otherwise a vacuum leak, then it will cause idle problems at this time.
There are many other possible causes, but these are good places to start.
Datalogging is also a great place to start. As you do your testing you might want to post further questions in the TBI section or the DIYPROM section.
Old Feb 28, 2010 | 11:38 AM
Vader's Avatar
How clean is the IAC?
Old Feb 28, 2010 | 03:21 PM
bcmag's Avatar
check t-body mounting gasket very closely for vacuum leaks
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
