How to know when engine is broken in?
Old Mar 7, 2010 | 11:35 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
I have a fresh 383 build with around 1100 miles on it. I have chromoley piston rings which i know take a bit longer to break in. How will i know the engine is broken in? Will it just stop smoking? It dosent smoke much, just a little faint puff every little bit.
Old Mar 7, 2010 | 11:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: How to know when engine is broken in?
With a flat tappet cam, it's broken in after you do the cam break in. With a roller cam, it's broken in within a few minutes after you start it.
Old Mar 7, 2010 | 11:53 PM
Engine: 383 Stroker
Transmission: t-56
yes but the piston rings are one of biggest reasons for proper break in. how will i know why they are broken in?
Old Mar 8, 2010 | 12:07 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A flat-tappet cam is the biggest reason for proper break-in. Rings are fairly forgiving of procedure.
Old Mar 8, 2010 | 12:10 AM
Engine: 383 Stroker
Transmission: t-56
So your telling me that if i go to my car right now and burn the tires down at 6k rpm, my rings will seat just as good as if i babied it?
Old Mar 8, 2010 | 12:18 AM
Iroc-dev's Avatar
Car: 1988 camaro Iroc-z 350(stick)!
Transmission: manual/ 5 speed.
Its what they said basically! You just know! Now its time for the good stuff....All the synthetics and all the performance enhancers! Please, whoop on all mustangs whom stand in your way, that wont be too hard!!LOL
Old Mar 8, 2010 | 12:23 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
they seat better when you hammer down on it. Do it early in the engines life with alot of engine braking to build vacuum in the crankcase. Helps force the rings out to the bore to properly wear into the bore shape. Thus it breaks in faster.
I would say 1100 miles is good to go race. I was racing mine after 75 miles or so...probably much less than that. Thats about how long it took me to tune the motor and tune WOT on the street. I was on the pedal probably 15-20 miles into the new motor
Old Mar 8, 2010 | 07:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Race engines like mine don't get broken in. They're also not intended to last 100,000 miles but we build them, fire them up and race them with no break in period.
If your engine is still burning oil after 1000+ miles, there's something wrong with it. The only oil it should be burning is the oil all over the pistons and rings when they were installed in the cylinders. That gets burnt off before the engine reaches operating temperature.
Old Mar 8, 2010 | 09:43 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
I've had an instructor tell me that you should avoid babying a freshly rebuilt engine because the rings won't seat properly at all and will instead glaze the cylinder walls, causing the engine to burn oil for the rest of its life. His advice was to let it run no more than 30 seconds on the first startup just to verify everything worked properly, then take it driving. He even recommended shutting it off at stoplights to avoid idling for the first couple hundred kilometres. To be fair, his advice wasn't very relevant to what we were learning (aircraft maintenance) but he was definitely a mechanically inclined guy that had rebuilt more than a couple SBCs.
Old Mar 8, 2010 | 10:00 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
My motor has 400 miles on it and I have been beating the hell out of it most of its life Mine doesnt smoke either.
Old Mar 8, 2010 | 10:17 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Mine actually broken in while trying to tune the carb after i dropped in my new motor, cam, head work, and carb. The only way i noticed it was because my motor started to ping and compression went through the roof. haha
Mine only took about 2 hours of varied rpms and some idling on top of the cam break in...I prefer to break the motor in by driving but its a good idea to vary rpms for the first 200 miles. I also dont like to beat the motor till 1000 miles so i dont spin a bearing or screw anything else up.
Old Mar 8, 2010 | 10:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If its going to happen it will happen. Doesnt matter if its soon in the engines life or later. Fire it up and run it. If it breaks then something either was done wrong in the install or just the bad luck of a poor quality part that failed prematurely
Old Mar 8, 2010 | 11:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I broke my 383 in on the way to the track and did 20+ passes.
No smoke/ oil useage but had crankcase pressurisation problems until 1000 miles when suddenly it went away so I can only assume that was when I got proper ring seal ( Hellfire rings / forged pistons)
Old Mar 8, 2010 | 11:37 PM
Engine: 383 Stroker
Transmission: t-56
so i should beat on it to break it in?
Old Mar 9, 2010 | 11:30 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
1100 miles is WAYYY too late to be thinking about break-in.
Beat on it! It's not possible to hurt anything at this point.
Old Mar 9, 2010 | 11:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Typical street engine break in procedure
Engine ready to fire up for the first time. Try to get base timing as close as possible before firing up.
Fire up engine and keep it running for about 30 minutes varying the rpms to break in the flat tappet cam. If a roller cam, this procedure isn't necessary.
If you had a flat tappet cam, after the cam break in, change the oil and filter.
Drive normally for 500 miles.
Change the oil and filter.
Drive however you want changing the oil and filter on regular scheduled intervals.
That's it. If the engine was assembled properly, it should last many trouble free miles.
Old Mar 10, 2010 | 01:16 AM
Engine: 383 Stroker
Transmission: t-56
alkyiroc, that makes the most sense out of all. Thank you
Old Mar 10, 2010 | 11:38 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
You're dead on the money , I build engines and this is method for which I break them in, I have yet to receive a complaint of early engine failure
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
timonator
Aug 11, 2015 09:56 PM
