more questions about timing...
Old Mar 10, 2010 | 06:29 PM
spiffiestpengui's Avatar
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
hey im still trying to get my timing right. I'm pretty sure it should be set at 6 degrees is that right?? I have a picture that i can show where it is lined up at but i cant figure out how to upload an image. If your looking from the front of the car, it is the third notch to the left of the big notch , which i think is tdc. i could be wrong. it still runs like crap they go by 2 degrees at a time right?
Old Mar 11, 2010 | 03:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stock carb set-up, right?
Each "mark" represents 2 degrees. The first "point" is 4 degrees, the first "valley" is 6 degrees. After that each "point" is another 4 degrees (8, 12, etc).
How exactly is it running? Smooth but with no power? Missing? Backfiring?
When was the last tune-up (plugs, wires, cap, rotor, fuel filter, etc.)?
Old Mar 11, 2010 | 05:45 PM
Engine: 305 v8
Re: more questions about timing...
well, its running a little rough, no power at all,until maybe midway through 3rd, but then it just gets slow again. it feels like its a 6 cylinder or maybe even worse. I just did an oil change, drained and refilled the transmission fluid, i didn't change the plugs but i took them all out and cleaned them...like 3 times within the last week or two, just got the new distributor about a month ago, and got brand new 8mm plug wires last night., and yeah its the stock 4 barrel carb. I know i need to clean my air filter, but that's not whats causing it because i tried taking it for a test drive without the filter, and it didn't make much of a difference.
Old Mar 11, 2010 | 06:08 PM
five7kid's Avatar
What "new" distributor did you put in?
Is your SES light coming on?
Old Mar 11, 2010 | 11:08 PM
Engine: 305 v8
Its just a duralast gold from autozone, and if you mean the check engine light, then yes. its stuck on, i accidently broke it i left one of those test keys and forgot it was in there. i turned it on and ever since then, the light wont go off or flash codes. i already tried unhooking the battery cables. but this happened along time ago and it ran fine until now.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
