Lifters not primed?
Car: 84 z28
Engine: 383 stroker
Transmission: th-350
Axle/Gears: 3:42
Lifters not primed?
Hey Guys,
doing a valvetrain upgrade here and i have the intake off, noticed that almost half of my lifters are hard and the others are compressable, took those out and placed in oil, used a pushrod to compress one of the "soft" ones and i can't get them to harden up. Happening to a few of them actually, does this mean the lifters are faulty?
The car has been laid up for a few months, I dunno if that helps. They were new speed pro hydraulic lifters.
Kinda stuck here,
Geoff
Kinda stuck here,
Geoff
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Lifters not primed?
if they are fairly new i wouldn't think they would be bad. can you prime the oil pump with a drill? they should stiffen up.
Car: 84 z28
Engine: 383 stroker
Axle/Gears: 3:42
I have a old dizzy that I could modify to prime the motor, shouldn't they "pump up" in a bath of oil forcing the air out? I tried a few different lifters and they weren't getting any stiffer at all.
I'm at a standstill because I don't wanna lash those valves with lifters that may not prime up.
if you're unsure about the lifters replace them. i've bought lifters from autozone in packs of 4.
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
CompCams specifically recommends NOT priming the lifters. You'll find that in their catalogs and during interviews with their engineers. They say it causes errors in setting the lifter preload.
Jake
Jake
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Keep in mind the lifters will compress as you've seen. However if the cam is in such a position where it is trying to lift the valve associated with that lifter it will already be compressed and will feel hard. The same is true with the soft ones. They are most likely not in a position where they are trying to operate a valve therefore they should be uncompressed giving them a soft feel.
Car: 84 z28
Engine: 383 stroker
Axle/Gears: 3:42
Hey rolling...
that actually makes sense to me now i think of it, I did manage to modify my old distributor to prime the motor for a good 20 mins, taking breaking so i didn't blow up the drill.
I think my lifters are in good shape, the car has only been driven up and down the street. I've been working on it for a few years now. I'll do a oil change since I did get water in the motor with the intake off, i'll then prime the motor with the fresh stuff.
Thanks guys for your help,
Geoff
Geoff
skinny z
Oct 5, 2015 06:23 PM
dimented24x7
Sep 6, 2015 03:51 PM
