Car doesn't want to start...
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Yesterday I got my car running and running good. Today i go to adjust my TV cable for the tranny and doing the WOT to closed numerous times was dumping fuel down the intake.
So i let the car set for about 4 or 5 hours and cranking it every so often so help push what fuel was being sucked in out the exhaust as mush as possible. Still no sputter or any sign of the wanting to start. The timing was all adjusted to 10* advance yesterday and was good when shut off.
After getting frustrated i decided to pull the plugs to get a look at them, they were all wet so i dried them off then placed back in. Well it still did not want to start so i pulled the #1 and #2 plugs and they seemed to be arcing between the electrode and the threads not the prong at the end so i checked the gap and they were .026 so i adjusted and put them back in.
I know it has good compression on all cylinders but I dont seem to know why it is acting up all of a sudden. It was starting up great yesterday but today it wont even act like it wants to start. This has me stumped.
Thanks for the help,
Chas
Chas
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Car doesn't want to start...
i would try some new plugs
Car: 86' IROC
Engine: 388
Thats what i was thinking. Also i dont know if this would have anything to do with my issue.
But when i was trying to time the engine my light would work some times but not others like the plug would fire then not...I'm thinking it has something to do with the same reason that its not starting.
Car: 86' IROC
Engine: 388
Ok so i replaced all the plugs with stock AC Delcos and no difference in starting. I checked the gap and they were all .035 before i put them in. #1 and #3 plugs both had spark.
Should I pull the plugs and check to make sure they all have spark?
The car is getting fuel but not starting. I'm thinking it has something to do with my timing...
Thanks, Chas
Thanks, Chas
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Subscribed.
Wish I could help, but I am having similar issues.
Good luck!
Good luck!
Car: 86' IROC
Engine: 388
She means well...I just need to get this thing running! haha
Car: 86' IROC
Engine: 388
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
did you prep the car to set the base timing? Air, Fuel, Spark is all you need.. I'm starting to believe timing may be off... mark your current timing by using some whiteout on your distributor cap and a fixed point, then I would turn the cap and see if you get life...
Car: 86' IROC
Engine: 388
I will try that in the AM.
Car: 86' IROC
Engine: 388
I managed to get the car to start. In the process of checking the distributor wires on the cap i managed to knock off one of the vacuum lines that connect to the master cylinder for my brakes and the engine was just sucking straight air. I connected the line and it started right up.
I hate it when i over look little things like that but im happy it is all fixed.
That prevented it from even sputtering? Crazy stuff.
I will have to double check my lines as well.
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Engine: 5.1 4bbl
Engine: 5.1 4bbl
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
