Map sensor problems
Old Apr 14, 2010 | 04:42 PM
marcos beltran's Avatar
Map sensor problems
I just replaced my 305 engine with a 350 tbi. When putting it back together I started having a problem with my map sensor. When the vacuum line is disconnected from the sensor the car runs and when I connect it the car shuts off. I tried a new one and it still does the same thing. Do I have a bad connector or is one of the wires going to it damaged or something?
Old Apr 15, 2010 | 12:21 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: Map sensor problems
i have heard that a 350 MAP is different from a 305 MAP, but not sure if it's true and if so, why. if it's the vac line you are disconnecting, check to make sure the line isn't collapsed or plugged up, as well as the port it is hooked to.
9192camaro
16
Feb 3, 2019 12:21 AM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
