About to do my first "fuel pressure test"
Old May 19, 2010 | 07:04 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
Car: 1988 Pontiac Trans Am ,
Engine: 5.0 litre TBI
The kit i am using is made by actron.
My question is , wich of the two fuel lines is to and from the tank " wich is wich ?" .
Old May 19, 2010 | 07:07 PM
Damon's Avatar
Re: About to do my first "fuel pressure test"
The larger 3/8" line is the feed (pressure) line. The smaller 5/16" line is the return.
Don't you hate that GM didn't put a simple schrader valve on the TBI engines where you could easily tap in to take a reading like on just about everything else?
Old May 19, 2010 | 09:20 PM
yeah , there would be less fuel on the floor onthe enginebay ,and more fuel in the tank , so im assuming this test will only verify if the fuel pump isgood or bad ? will it let me know if my FPR is not working right ?
Old May 20, 2010 | 10:13 PM
Damon's Avatar
Both, really. If it reads low it could be either one. If it reads high that can only by the FPR or an obstructed return line.
If you can possibly rig it up so you can see the gage when you drive that's another test you can do. Proper pressure at idle is only one check. If pressure drops off when you put it under load (like making a quick WOT run through a gear or two) then the fuel pump isn't keeping up with demand. Clogged fuel filter, dying pump, inadequate voltage to the pump, etc.
Old May 20, 2010 | 10:16 PM
did the test , 11psi @ idle , should be good . TBI's should be between 13 and 9 psi right?
Old May 21, 2010 | 01:01 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
With my TBI pump it put out over 15psi... That may be a bit low.
Old May 21, 2010 | 03:55 AM
Pat Hall's Avatar
I wouldn't think 11 psi would be problematic on a TBI. BTW, if you ever do decide to replace your in-tank pump, just put a TPI pump in there. The regulator in your TBI unit will keep the pressure where it should be, and it shouldn't ever suffer from the pressure being too low. I ran a TPI pump in my TBI car for several years without any problems at all. I just recently swapped in a tuned port motor and it was nice to already have the higher pressure pump in the tank! If you went with a TPI pump, you could put in a high quality pump like the Walbro when it comes time for replacing it.
Old May 21, 2010 | 06:27 AM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
Old Jul 28, 2010 | 09:18 AM
Jabpir8's Avatar
Car: Buick RMW 92
Engine: L05 5.7L V8
Transmission: 4L60
I want to check the fuel pressure on my L05 TBI (92 RMW) to set my EBL flasher properly.
Are there any kits existing that would bolt on simply on the fuel lines ???
if not how do you guys proceed ????
Old Jul 28, 2010 | 09:44 AM
Jabpir8's Avatar
Car: Buick RMW 92
Engine: L05 5.7L V8
Transmission: 4L60
ooops
Found Sunpro # CP7817 GM TBI Tester.
seems perfect for the job !!!!!! (58 USD)
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
