No Idea Where to Post this Question?:S
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
Don't really know where this should be asked, however, I have a problem with when I'm taking off from a stop in first gear, once in a while, when I get a rough start
, something in the back rattles like CRAZY. Anyone know what it is/could be?
, something in the back rattles like CRAZY. Anyone know what it is/could be? Senior Member
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: No Idea Where to Post this Question?:S
Check everything from trans tailshaft back. Open your rear diff and inspect the gears. It could be nothing - just a little wheel hop, or, it could be chewed up rear end gears and/or improperly aligned pinion, broken torque-arm, etc.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
ck. your trac brace/panhard bar . it runs from pass. side of rear axle to drivers side of uni-body . it should be held on by 3 bolts . makes a nasty noise when bolts fall out . i know firsthand . good luck .
check the easy stuff first, like the licence plate holder or the spare tire/jack.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
